A couple of weeks ago you guys were kind enough to give some advice here on a ceiling for a friend of SWMBOs having a hard time with ex-hubby and money.
She has bravely taken the next step and is moving in and now wants me to try and fix up the ceiling as best I can.
That means I am back for some more practical help on actually doing it.
I intend using 12.5mm board directly onto the current ceiling help in place with 75mm drywall screws directly into the joists. The ceiling although cracked is flat and the additional effort, time and more importantly money for battening doesn’t seem to be worth it.
Taking Richard C’s advice I intend to paint with matt emulsion until money available to skim the ceiling. And this is where the help is really needed.
How do I make the joints look acceptable until the ceiling is skimmed.
Do I:
1) butt the boards closely, then use jointing tape and then joint filler over the top
2) butt about 2 or 3 mm apart, fill the gaps with joint filler, then when dry cover with joint tape
3) Other
Will it be OK to use builders caulk around the edges to seal the gap to walls?
Help much appreciated.
Do I:
3) Other
