I got a 1/4" set from bosch for about £10, has Roman Orgee, round over, dovetail cutters and flat cutters and does what I need it to. Not supreme quality but good enough.
I'm pretty sure i'm getting the makita 3612.. a 1/2" router, but might also get a smaller 1/4" one for lighter work.. so i guess a 1/4" set would do for both? Budget.. up tp around £50?
buy any one off the budget sets with 24 to 50 pieces then as you work out the ones you use the most then you replace them with toledo[rutlands]medium quality or trend that go up in stages to cmt and others at the top off the market
look for a rebate/rabbet]cutter with alternative bearings they deside the width off cut whilst the plunge decides the depth
get yourself a nonslip matt and ptfe lubricant spray from toolstation
