I guess from reading a lot of these posts I am just about to get abused from left right and center, still if i dont ask i dont learn, so here i go!
you are able to spur of a socket with 2.5 cable as you can only pull off supposingly 13Amps from a single / double socket.
therefore why cant you use 1.5 cable (rated 15A)?
main question is though, I have just bought a house and there is a security light in my back garden and this has been attached striaght into the back of a socket on my ring main, which is ran from a 32A breaker protected by a RCD, the cable is 1.5mm.
now i know this is deffo a no no, still...... this security light will never be able to pull more then 2 amps (it only has a 150w bulb in but guess it could go to 500w), so this cable will never overload. so what is the real problem.
Hopefully some one will be able to explain the actual problem and not just state BS numbers, firstly because i dont have the book and secondly because i have asked for a general explanation.
Hoping this doesnt come across as aggresive as I would like my question answered.
