Have the chance to buy this particular model at a good price & believe Buderus are one of the best.
That's what some say. There have also been rumours that Buderus are pulling out of the UK.
Have you checked that the installer is familiar with them and that he is happy to let you do the "donkey work"? There is a grey area over what the installer must do. Many installers say that it is their responsibility to hang the boiler, install flue and all gas work.
Do you realize that, if you supply the boiler, the installer has no responsibility if it is faulty or goes wrong?
I have 10 (potentially 12 as 2 are always turned off) radiators with 2 bathrooms. Admittedly, the boiler stat is always set low (between 2 & 5) so you could be right with the calcs so I'll measure up & find out. Should this necessarily affect buying this boiler as I thought it would modulate to suit?
The Buderus website says:
The 800 Range of gas condensing boilers are designed for very large domestic properties. Suitable for use in light commercial installations.
I would not call 12 rads and two bathrooms "very large".
As for modulation, it's true that the boiler will modulate down to produce the correct amount of heat, but the boiler is sized for worst conditions, -1°C outside. The heating requirement is not constant; it varies with the outside temperate. So, if you need 20kW for a temperature of -1°C, you only need 10kW when it is 10°C outside and 0kW when it is 21°C.
If your boiler can only modulate down to 15kW, then for most of the year it will be acting like an non-modulating boiler, i.e in on/off mode.
