I'm fitting an isolator board which will have piro's terminated into it (with earth concentric pots) which feeds submains upto flats. This is fed via a ryefield board etc.
I'm taking the concentic pots into the earth bar and the main earth coming in (35mm) onto the bolt which is directly onto the metal enclosure of the isolation board.
My question is, do I need to bond between the side enclosure (where the main earth is) and the earth bar or is using the metal casing which already links the bar and the casing adequate?
I'm thinking they should be linked but have been told overwise. Thanks
