garrymum
Joined: 16 Sep 2004 Posts: 638 Location: Leeds, United Kingdom Thanked: 4 times
Posted: Thu Mar 25, 2010 10:22 am |
Hi
Adding a breakfast bar to our kitchen. Worktop is 38mm thick. What size batten should I fix to the wall for the breakfast bar to rest on? It will be supported with 1 or 2 legs as well (opposite side to the wall).
Thanks |
kevindgas
Joined: 28 Mar 2006 Posts: 5588 Location: Southampton, United Kingdom Thanked: 438 times
Posted: Thu Mar 25, 2010 10:28 am |
use 2"x 1" for the back support screw to wall at approx 12" intervals
i always run a bead of no nails along the wood before fixing to wall (belt and braces  )
then use screws at a 45 degree angle to secure worktop to wood |
ColJack
Joined: 16 Feb 2007 Posts: 11772 Location: West Midlands, United Kingdom Thanked: 408 times
Posted: Thu Mar 25, 2010 2:11 pm |
45° angle? please explain..
do you mean sideways as surely it's impossible to angle back to front as te wall prevents the drill going that way, and going front to back kind of defeats the object as you wouldn't even touch the worktop
what's wrong with using angle brackets screwed to the batten and worktop to secure it? |
big-all
Joined: 12 Jul 2004 Posts: 12192 Location: Surrey, United Kingdom Thanked: 659 times
Posted: Thu Mar 25, 2010 4:57 pm |
assuming your tiling or are happy to have a 6mm bead off silicon
use some angle iron[steel /aluminium /stainless]drill a hole every 150-200mm to screw into the wall in the area the worktop will cover
remember the holes you drill to go into the worktop will be on the outside face
you will have to chamfer the bottom edge to sit in the curve on the metal
this way theres no more than the 6mm protruding with no ugly brackets blocks or battons showing unless you drop your to worktop height |
