I've got a Hotpoint Aquarius 1200 Washer Dryer WD62. The problem is that when I put it onto the drying mode it doesn't dry the clothes. If anything they seem wetter (although the clothes are quite warm when I open the door). Can anyone tell me what the problem is?
Also check the fan which sits in the top of the machine. The washer driers have a big back panel held on with unpteen screws. If you get this off you will see the bottom hose that runs from the drum to the pump. This incorporates a plastic cage that catches stray coins, socks etc.
