DIYnot
Local | Network
   DIYnot > Forums
Local | Network
removing paint from upvc window frames
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
scousespark
from United Kingdom
Thanked: 40 times
PostPosted: Wed Apr 14, 2010 11:31 am Reply with quote
I have a upvc window frame with scraps of old gloss and emulsion on it and I wanted advice on the best way to shift it.
The window has a mock woodgrain finish and I don't want to damage it.
What's the best option for getting rid of this paint?
Am I best using a fine glass paper to rub gently, or wood a paint remover do the job?
Any advice gratefully received.
Back to top
 Alert Moderators
LJW61
from United Kingdom
Thanked: 63 times
PostPosted: Thu Apr 15, 2010 7:18 am Reply with quote
What colour is the plastic?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1511 times
PostPosted: Thu Apr 15, 2010 1:11 pm Reply with quote
do the emulsion first, it is easy
you can soften it with meths. To prevent it running off or evaporating, mix it with washing up liquid, brush it on generously, flop over it with a piece of kitchen roll soaked in the mixture, cover it with cling film to stop it drying out.
The next morning it will probably come off when you rub it with the still-wet kitchen roll or a coarse cloth. A toothbrush can be used if needed. If you let it dry out it will go hard again.
Be aware that the woodgrain is just a patterned plastic film stuck to the plastic frame, so be careful not to damage or remove it
Back to top
 Alert Moderators
scousespark
from United Kingdom
Thanked: 40 times
PostPosted: Thu Apr 15, 2010 9:06 pm Reply with quote
Cheers for that John. I was not sure if this was something to worry about.
I'll try that tomorrow night and hopefully clen it up on Saturday morning.
LW, the frame is an oak clour. The windows were fitted about 3 years ago, when the original owner was doing the house up to sell. The window in question is in a box room and I want to use this as a study.
The owner appears to have used masking tape around the frame, but some of the paint (emulsion and gloss) has got under the tape and looks a bit messy. There are also a few streaks, where he has gone over the tape. There is not a massive amount to remove. I'm just wary of spoiling the frame.
Back to top
 Alert Moderators
middleman
from United Kingdom
PostPosted: Sat Oct 04, 2014 7:10 pm Reply with quote
Holy Thread Revival Batman!
I had this problem a few days ago with emulsion paint on a mock woodgrain mahogany window frame in my house that I can only assume was painted by Stevie Wonder.
I had been searching on here and came across this thread. Was going to try the fairy liquid and meths and then came across this stuff in B&Q so thought I would share it here as it worked for me..
http://www.diy.com/departments/home-strip-paint-stripper-500ml/254572_BQ.prd
I used it like this.
1. Apply product with small brush to the area
2. Leave for 30-60 mins to work
3. Use Stainless steel scourer available in most supermarkets to run over and remove most of the paint
I found it will smear on the surface and from the wall
4. Use cloth with meths to clean off excess and clean frames
Back to top
 Alert Moderators
Bosswhite
from United Kingdom
Thanked: 170 times
PostPosted: Sat Oct 04, 2014 8:02 pm Reply with quote
personnaly I would use Paint Brush Cleaner its less abrasive and can be washed off with soapy water.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
how to remove paint around window that has upvc frames 2 240 Mon Feb 07, 2011 10:54 am
Kitchen and Bathroom Sealant for uPVC window frames? 6 760 Thu Feb 25, 2010 7:58 am
removing spilt masonary paint from upvc window frame - help 7 3060 Mon Mar 27, 2006 9:26 pm
Removing emulsion from UPVC window 7 4200 Mon Apr 21, 2008 2:56 pm
uPVC window sills damaged by paint stripper? 3 160 Sun Dec 30, 2012 2:20 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
