DIYnot
Local | Network
   DIYnot > Forums
Local | Network
radiator temperature dial - All or Nothing
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Author Message
sstandard
from United Kingdom
PostPosted: Wed Mar 12, 2003 9:18 am Reply with quote
Hi
I have a number of radiators with there own temperature dial.
There are about 5 or 6 settings on each dial. However I cannot get ANY heat out of them unless i set them to the almost maximum setting (it varies slightly from radiator to radiator). Therefore, my house is either like a sauna or an ice box, there is no in between. Does anyone have any ideas what could be causing this and if there is anything i can check?
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Wed Mar 12, 2003 4:12 pm Reply with quote
Could be your radiator thermostat valve sticking with built-up of corrosion.Depend what type you've got,you can take the cover off(usually a allen key lock in somewhere) then you will find a pin which operate the valve.Pull it out slighty with a plier without taken it right out (careful not to damage the pin) and clean the pin with WD40 and rags or 00 steel wools,then see if you can move it backward and forward.Don't worry if the pin come out,it will go back in with some diffculty but water will dribble out.The way the thermostat works e.g. high setting pin out,lower setting pin in.I think what happening in your case the pin won't go in for lower setting therefore hot radiator.Best to get a plumber if you're not sure.
Back to top
 Alert Moderators
MANDATE
from United Kingdom
Thanked: 129 times
PostPosted: Wed Mar 12, 2003 7:17 pm Reply with quote
A couple of aspects to consider.
You will most likely have a room stat that switches the circulating pump on and off and when the set temperture is reached the pump stops.
You can appreciate that thermostatic valves are individually set (1/4 open 1/2 open 3/4 open fully open) but unless the pump is running they cannot function correctly, as hot water is not being pumped through them. Try the room stat at a slightly higher setting.
My second point. Prior to radiator stats each radiator had two lockshield valves fitted, one was used as an ON/OFF valve and the other adjusted to restrict the flow of water in order to achieve the desired temperture,now if any of these are almost closed and water flow restricted then it's pointless having radiator stat valve fully open
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
temperature fluctuation 2 2940 Mon Sep 23, 2002 11:36 am
Halogen vs tungsten colour temperature 5 1400 Tue Jan 28, 2003 11:42 am
Flat temperature 10 720 Tue Jun 02, 2009 9:44 am
1 cold radiator 2 660 Sat Mar 22, 2003 10:13 am
Removing Radiator 3 660 Sat Mar 15, 2003 3:54 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
