Where?Switchfuse is for the Garage electrics.
Why?Before the refurbishment work, there use to be an older Wylex Switchfuse, which then goes into a smaller fuse box for the Garage and side extension.
Where?I have the SWA cable 16mm 3 core which was terminated on the old metal wylex box, and now need to install the new box.
Why?So I wanted to install the new switchfuse with the new 17th edition Wylex fuse box. Fuse box has already been wired and configured. So now need to installed the Switchfuse before I can switch on the electrics
Given your knowledge of circuit design, tell us what factors affect which way you connect it.The problem with this Fuseswitch unless its me, its written L N and E but it does not say input/ Load hence why I wanted to make sure I wire it correctly.
So what would happen if you wired it the other way around?Im assuming the "In" connections will be at the top end of the fuse and the laod aspect will be at the bottom. That makes sense to me as in the off state of the fuse button, the off maker is placed on the top end and by pressing the button on, pulling it down the current is switched and passed to the load..............
So what is the point of the switchfuse?Where? Not to sure what you mean by this, the Switchfuse is in the Garage, from the meter which is inside the house I have a isolater switch after the meter so the two tails go into the isolater switch. From there it then goes into two single pole blocks (i think its called henley)
from there one goes into the main house CU and the other two tails go into the Garage to this Wylex SwitchFuse.
