Hotpoint WD420 Lights Flashing / Won't Spin
26 Apr 2010
Help, our WD420 has just died. I've read all the other posts but can't find any that match our fault, (or I can't read the right lights!)
Today, it did a wash but when it came to empty and spin, it failed. I think I've fixed the 'empty' bit (the filters were all blocked with pocket debris) but it won't spin. It starts to spin but stops after 30 seconds with the on/off light flashing rapidly and the 'Drying High Heat' light flashing as well. Any ideas?
Thanks in advance
Paul
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
PCB IS SHOT EXCHANGE PCB FROM HERE OR SCRAP IT http://www.emwelec.co.uk/index.php?action=category&id=1 YOURS IS F08 HEATER RELAY OR HEATER RELAY ON PCB .
f16 N/A
Hi thanks for the speedy reply. Is their a difference between heater relay and heater relay on the PCB? I only ask as we are in New Zealand and bought the washer with us from the UK, spares are not readily available! Is their a circuit board schematic available ??
Cheers
Paul
What I meant was it's either heater or the heater relay on the pcb ,heater is found at the rear of the mc under the white cover ,measure it with a meter should read 30 ohms.the heater relay is on the pcb found in the same place but in the corner covered in a white plastic cover , pcb are normally just replaced unless you know someone who can repair pcb.
