Quick way to determine central heating water flow direction
31 Mar 2010
Bradford
I have had to remove a radiator and have turned off both valves so when turning the water back on everything should be great.
But I would like to know if there is a quicker way to determine which direction the water is flowing in and out of other than ripping up the floorboards and taking a look?
Can you help?
connect the valves together with a pipe/hose, turn valves on, feel pipes.
