DIYnot
Local | Network
   DIYnot > Forums
Local | Network
cavity wall insulation pushing blocks out during constructio
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
garyo
from United Kingdom
Thanked: 31 times
PostPosted: Thu May 13, 2010 11:23 am Reply with quote
As I build the inner leaf of my extension, the 85mm rockwool insulation bats always seem to exert a slight outward pressure on the blocks. This means that regardless of how well they're placed, they always end up leaning out at the top.
I'm using drytherm bats. My outer leaf is made from reclaimed bricks of various sizes, which means that the cavity is only 75mm thick here and there, so this could be part of the problem.
I've been dealing with it so far by placing a spare block up against the block I've just laid to keep it in check, but as the height of the internal leaf rises, this approach is becoming impractical. It seems equally silly for me to have to hold the block in position for 5 minutes in order for it to go off.
Thanks!
Gary
Back to top
 Alert Moderators
Static
from United Kingdom
Thanked: 155 times
PostPosted: Thu May 13, 2010 11:46 am Reply with quote
So your putting 85mm insulation in a 75mm cavity? Is that what the manufacturers recommend?
Back to top
 Alert Moderators
garyo
from United Kingdom
Thanked: 31 times
PostPosted: Thu May 13, 2010 1:54 pm Reply with quote
The cavity is 85mm for 90% of the time. The odd brick is 5 to 10mm thicker.
I get the impression that the bats are nominally to suit an 85mm cavity, but in reality expand to 90 to 95mm and need to be compressed into the cavity. Hence the problem.
Back to top
 Alert Moderators
stuart45
from United Kingdom
Thanked: 125 times
PostPosted: Thu May 13, 2010 2:30 pm Reply with quote
You should have made the cavity a bit wider. You are allowed a small bit of extra tolerance. As you can see it's not practical to have too small a cavity.
Back to top
 Alert Moderators
RonnyRaygun
from United Kingdom
Thanked: 139 times
PostPosted: Thu May 13, 2010 2:40 pm Reply with quote
I reckon you're either going to have to get some 75mm insulation (which BC might not allow) or build up a couple of courses of block at a time, let the muck set, then push in the insulation batts.
Back to top
 Alert Moderators
garyo
from United Kingdom
Thanked: 31 times
PostPosted: Thu May 13, 2010 2:46 pm Reply with quote
I think the use of thermalites doesn't help - they're so light they don't have the presence to deal with even a small amount of pressure.
Back to top
 Alert Moderators
garyo
from United Kingdom
Thanked: 31 times
PostPosted: Thu May 13, 2010 2:48 pm Reply with quote
Thanks for the replies.
I'm already four courses of blocks off floor level using the existing technique. I think trying to push the insulation in afterwards would be even more painful than temporarily leaning something on the blocks.
Back to top
 Alert Moderators
stuart45
from United Kingdom
Thanked: 125 times
PostPosted: Thu May 13, 2010 2:57 pm Reply with quote
[img]
This is the accepted tolerance.[/img]
Back to top
 Alert Moderators
theoldun
from United Kingdom
Thanked: 279 times
PostPosted: Fri May 14, 2010 6:58 pm Reply with quote
First you say you have got 85mm Rockwall Slabs. Rockwall do not do 85mm slab. You then say Drytherm, What I reckon you have are Earthwool Dritherm Slabs (rock), Crown, Knuaf, which are 85mm. thick.
If this is the case, you have two options.
Either rattle it over and clean blocks up and re-lay with a 100mm laid cavity, or corbel over by 25mm and plumb up from there. Dub your bottom out with two scratch coats 4&1 sand cement. Suggest first option, unless you can lay decent block.
You are allowed to corbel over 25% of laid width. Guidance only. old un
Back to top
 Alert Moderators
jeds
from United Kingdom
Thanked: 264 times
PostPosted: Sat May 15, 2010 9:16 am Reply with quote
Build the inner leaf first.
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 851 times
PostPosted: Sat May 15, 2010 9:43 am Reply with quote
It is normal to get a little push.
For instance, when building 100mm cav's we actually build them 110mm so as to allow for the expansion and does not affect the lintels.
Building the blockwork first is a nightmare.
Back to top
 Alert Moderators
cyclonebri1
from United Kingdom
Thanked: 1 time
PostPosted: Wed May 26, 2010 8:22 am Reply with quote
I wouldn't have thought you have a problem as an out and out amatuer, (assumption).
I cannot see you laying more than 2 courses, 1 batt high all round in a session. Use enough brick ties and you will have no issues inserting the stuff the next day before you mix again, icon_lol.gif icon_lol.gif icon_lol.gif
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 851 times
PostPosted: Wed May 26, 2010 5:15 pm Reply with quote
Two courses of blocks, you avin a larf!?!?
There are few extensions that we can't get up to lintel height and beyond within one day. That is two brickies going at it with one dropping off to do the labouring.
Back to top
 Alert Moderators
stuart45
from United Kingdom
Thanked: 125 times
PostPosted: Wed May 26, 2010 8:20 pm Reply with quote
[quote="noseall";p="1625750"]
Two courses of blocks, you avin a larf!?!?quote]
He's not joking, I can do 2 courses on a good day.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
Cavity Wall Insulation and Thermal blocks 3 200 Thu Jan 20, 2011 7:22 pm
whats the best blocks and cavity insulation to use? 5 920 Tue Dec 09, 2008 7:11 am
New wall advice needed re blocks,cavity, solid? 4 60 Wed Jun 20, 2012 9:19 am
Wall built with foundation blocks. Insulation requirements? 13 180 Wed Oct 03, 2012 6:25 pm
Insulation Blocks 2 300 Sun May 16, 2004 6:43 am
DIYnot
