DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Aqualisa hydramax problem
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
presidiot
from United Kingdom
PostPosted: Sun May 16, 2010 3:26 pm Reply with quote
I have a new hydramax. The water is either hot or cold - nothing in between. I've taken it apart to check that the cartridge works Ok and it does. it's a HP green one.
Looking through other posts it seems that there might be a problem with the o ring but i can't find enough detail to check. The best I can do without draining the system again to get it out and photograph is a description :-
The opposite end to the heat control of the cartridge is a 15mm (approx) pipe with a small conical filter in there. Around the outside of the that pipe is a rubber o ring. Should that o ring be fitted inside the plastic component of the shower enclosure. Looking onto the plastic coupling I can see (and feel) a small groove that might house the rubber o ring.
If not then what is the o ring doing as when the pipe slides up and down in response to temperature control adjustments it seems to be about 10mm away from the hole where the water comes in. I don't think that the o ring is sealing anything.
Any ideas or help would be appreciated.
thanks
pres.
Back to top
 Alert Moderators
presidiot
from United Kingdom
PostPosted: Mon May 17, 2010 1:29 pm Reply with quote
Hi all,
Update and solution that might help someone else.
The installation Q&As suggest that the pipes might be connected the wrong way round for these symptoms - they weren't. However, the fitting was installed upside down which achieves the same effect.
Looking at the fitting with the cartridge removed, there should be a banana shaped hole on the right-hand side. In my case it was on the left. So, I can either rip out the shower fitting or else reroute the pipes.
Being as it's already tiled in then I thought about it for 10ms and decided to reroute the pipes and connect them the other way round.
Hope this helps someone.
cheers
Pres
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Aqualisa Quartz problem 3 80 Sat Feb 02, 2013 7:15 pm
AQUALISA AQUAVALE PROBLEM 8 360 Fri Mar 26, 2010 10:10 am
Aqualisa power shower problem 2 80 Mon Jul 23, 2012 5:23 pm
Shower Pressure / Flow Problem Aqualisa Opto Thermo 2 60 Wed Sep 26, 2012 8:54 am
Problem with Aqualisa Quartz digital shower 3 2980 Sun May 31, 2009 8:01 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
