Potterton Suprima System L
17 Jun 2010
My hot water was coming on when not switched on, even when I removed the programmer, so I replaced the programmer (with identical one). Still had the same problem, checked in loft and zone valve was ceased. I replaced the zone valve, and when i turned fused switched spur on a little bit of smoke came out of new zone valve, and fuse blew. I checked whether the valve was open or closed and repositioned zone valve in correct position. Then when I turned the programmer on CH it worked, but as soon as I switched HW on it fused at the spur switch. Any suggestions as to what is wrong, I have been told that there may be a problem with a neutral on the PCB??
What valve did you take out, and what was it replaced with?
David
And it will have cost you more money on DIY than if you had got a pro in to sort it :LOL: :LOL: :LOL: :LOL: :LOL: :LOL:
