Joined: 26 Jun 2002 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Wed Jun 26, 2002 1:12 pm Post Subject:
Irregular Shapes
Can someone extend some help regarding creating a template for irregualr shapes. I've heard of an "adjustable shape-tracing template" that may do the job. I've got to cut around a toilet and some door molding. I did one bathroom by using the trial and error guess method w/ a piece of cardstock cut to the size of my tile. It took hours and I'm trying to find a better way. I don't want to lift the toilet or trim the molding. Please help.
If you don't want to see this advert, click here to login or if you are new click here to join free.
Guest
Posted: Wed Jun 26, 2002 2:36 pm Post Subject:
Re: Irregular Shapes
Take the side of a cardboard box and use a craft knife. I've always used a piece of card and gradually cut out the shape whilst constantly fitting to check it is still OK. I've used this method over the years on many a problem area - never made a mistake yet!
Posted: Wed Jun 26, 2002 2:38 pm Post Subject:
Well, I was thinking of making a mold to use over and over again. You say just user card-board can keep making cut after cut. I guess I can do that but I figured there must be some mold-putty type product on the market that fits into a shape and then can be traced later. Guess I might be wrong or need to invent something like that!
Joined: 09 Apr 2003 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Wed Apr 09, 2003 1:57 pm Post Subject:
Irregular Shapes
You can obtain an inexpensive tracing tool, from Gamleys (a Toy Shop in the UK). Maybe you could check out stationers for drawing equipment, or toy shops in your own area.
It creates an exact copy onto a piece of paper (or flooring tile) as you require.
Joined: 28 Jul 2003 Posts: 5 Location: United States of America Thanked: 0 times
Posted: Mon Jul 28, 2003 4:26 am Post Subject:
Vinyl tile - A simple trick for those pesky odd corners
A friend's trick, one I use, is to (step 1) press solder wire (soft, easily bendable) against the shape. I use a pen tip to get it into corners. Next (step 2) mark where, on the tile edge, the "funny shape" needs to begin, and where it needs to end. Finally (step 3) trace the outline of the solder wire (careful -- don't change the shape until it's traced!) onto the tile by placing the ends of the solder wire between the beginning point and end point you marked (step 2) on the tile. This method is ideal for working around doorway moldings and other things protruding from a wall.[/u]
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
