DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Garage door opening - type of lintel
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
Author Message
pompei
from United Kingdom
PostPosted: Thu Jul 15, 2010 2:34 pm Reply with quote
Hi, I'd be very grateful for any advice on a project I'm contemplating...
I've got a detached single garage built in the late 1920's with solid 9 inch walls and a pitched slated roof. On the opposite wall to the main vehicular entrance there is a personal door opening, the load above being supported by two timber lintels. I want to widen this opening to allow a car to pass directly through the garage.
My question is what would be the best way of spanning the opening? I guess that taking into account end bearings, I'd be looking at a 2700mm lintel. Would two concrete lintels do the job, or is it necessary to use a steel lintel if available - the steel lintels I've looked at have all been for a cavity wall at that length.
Thanks in advance for your help.
Back to top
 Alert Moderators
DOHdesigns
from United Kingdom
Thanked: 214 times
PostPosted: Thu Jul 15, 2010 4:07 pm Reply with quote
There's no reason why you can't use a normal beam (UB/UC). I wouldn't know what size but maybe something along the lines of a 203 x 203 UC. What would be the easiest thing would be to see what has been used on the other side and then use that for the rear icon_wink.gif
Back to top
The following user says thank you to DOHdesigns for this useful post:
pompei (15 Jul 2010)
 Alert Moderators
pompei
from United Kingdom
PostPosted: Thu Jul 15, 2010 4:59 pm Reply with quote
Thanks for that - the original main opening has a timber lintel. I assume it's better to avoid that arrangement?
Back to top
 Alert Moderators
themiddleagedun
from United Kingdom
Thanked: 58 times
PostPosted: Thu Jul 15, 2010 5:43 pm Reply with quote
You can get "T" shaped lintels for solid 9'' walls that would do. Or as you say 2 concrete lintels 6''x 4'' would also be suitable.
Back to top
The following user says thank you to themiddleagedun for this useful post:
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
What type of Lintel for a 3m Garage door gap? 6 7180 Sun May 07, 2006 6:39 am
Which Type of Garage Door 3 60 Fri Apr 26, 2013 11:16 pm
Identify my house type and advice on garage door to suit 3 380 Mon Apr 13, 2009 3:42 pm
Type of Lintel for Doorway into Garage 8 140 Sun Apr 14, 2013 1:49 pm
Type of door/gate lock 3 80 Thu Aug 29, 2013 1:13 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
