DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Wickes slim plastic cistern - side fill to bottom fill?
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
1066
from United Kingdom
PostPosted: Fri Jul 30, 2010 6:54 pm Reply with quote
I want to replace an old slim plastic cistern with something similar. The existing one is a push button one with bottom fill and bottom overflow but I can't find a direct replacement.
Wickes do a slim plastic one for £22.00 which sounds good but is side fill and side over flow although the info on the Wickes website says it can be made into a bottom fill with additional items.
I went into my local Wickes today to ask what was required but they didn't seem to have a clue.
Has anyone any experience with this cistern and know what is required - I know I could re plumb for side fill but there is not much room.
Back to top
 Alert Moderators
Fluffster
from United Kingdom
Thanked: 21 times
PostPosted: Fri Jul 30, 2010 8:49 pm Reply with quote
Get a flush mechanism with a built in overflow so no external overflow pipes required. Bottom or side entry is just a case of drilling a core hole in the base and blanking off the side inlet hole.
Pete
Back to top
 Alert Moderators
jobloggs
from United Kingdom
Thanked: 8 times
PostPosted: Fri Jul 30, 2010 8:52 pm Reply with quote
http://www.bes.co.uk/products/119.asp
see above for blanking plugs (also bottom entry plastic cisterns
Back to top
 Alert Moderators
seco services
from United Kingdom
Thanked: 1215 times
PostPosted: Fri Jul 30, 2010 9:03 pm Reply with quote
the wickes one already has a bulit in overflow in the syphon.
Back to top
 Alert Moderators
oldbuffer
from United Kingdom
Thanked: 14 times
PostPosted: Fri Jul 30, 2010 11:51 pm Reply with quote
Might be worth looking at Fordham. Google "Fordham cistern"
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1089 times
PostPosted: Sat Jul 31, 2010 4:27 am Reply with quote
I prefer a side fill, one less place to leak, and you can change the valve without having to drain the cistern
Back to top
 Alert Moderators
1066
from United Kingdom
PostPosted: Sat Jul 31, 2010 7:41 am Reply with quote
Thanks guys - After a bit of research I see the existing one is a Fordham. A replacement one looks as it will be over £100 so is a non-starter.
The ones from BES look promising so I think that is the way to go - £29 including vat and delivery and are bottom or side fill anyway.
1066
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 718 times
PostPosted: Sat Jul 31, 2010 12:58 pm Reply with quote
Fordham Flush Panel icon_idea.gif Used to replace high level clunkers icon_lol.gif where the pan was close back to the wall - Now high level Victorian repro is back in fashion : If you`re in 1066 country icon_wink.gif Look no further than the Plumbers Mate in Eastbourne - they even have a website now.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
slim cylinders 3 280 Tue Apr 01, 2008 8:54 pm
problem with a Radiant rsf 24e Slim combi boiler 5 720 Thu Apr 15, 2010 8:11 pm
Slim Trim pipe cover-----poor result 3 900 Mon Feb 28, 2005 10:52 pm
Radiant RSF 24 E SLIM not lighting. 3 40 Fri Dec 16, 2011 8:08 pm
Slim shower tray overflow! 15 360 Thu Sep 13, 2012 8:52 am
DIYnot
