DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Brand new radiator wont get hot
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
diystupid
from United Kingdom
PostPosted: Fri Aug 06, 2010 10:50 pm Reply with quote
Hi, I have installed a new radiator tonight, complete with a TRV. This is set at 6 and the lockshield is open. But it gets luke warm across the top and stone cold at the bottom. Have felt the inlet pipe and this is boiling hot. Both radiators before and after this one are piping hot. What am I doing wrong. I have taken the TRV off and made sure the pin goes up and down. It does. Any advice.
Back to top
 Alert Moderators
Hugh Jaleak
from United Kingdom
Thanked: 703 times
PostPosted: Fri Aug 06, 2010 11:00 pm Reply with quote
Possibly air locked. Try shutting off all the other rads to force the flow through the new one, see if this solves the problem. You may then need to balance the system. (See FAQ's if you're unsure on how to balance.)
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1467 times
PostPosted: Fri Aug 06, 2010 11:05 pm Reply with quote
which pipes did you attach it to?
Back to top
 Alert Moderators
diystupid
from United Kingdom
PostPosted: Sat Aug 07, 2010 8:58 am Reply with quote
I attached it to the existing pipework. Sorry, should have said brand new radiator replaced an old one.
If I turn the rads off before and after this new one, would that force an airlock out or do I need to turn all the rads off in the house?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1467 times
PostPosted: Sat Aug 07, 2010 9:05 am Reply with quote
OK, so you took off an old radiator and connected the new one to the old pipe stubs that came through the floor? Did the old rad work OK?
was it connected to 15mm pipes, or 22mm, or 10mm?
is your system pressurised or does it have a feed and expansion tank in the loft? Is this rad upstairs or down?
if you have an airlock you need to turn off all the other rads
but if you take the rad off again, open each rad valve and let them squirt into a bucket. That will do it, and will also verify the flow.
how old is the system and how much dirt came out of the old rad? what colour? Did you do any cleaning or flushing?
Back to top
 Alert Moderators
picasso
from United Kingdom
Thanked: 1278 times
PostPosted: Sat Aug 07, 2010 9:13 am Reply with quote
overdone the ptfe tape ?
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2755 times
PostPosted: Sat Aug 07, 2010 9:59 am Reply with quote
Open vent by any chance?
Back to top
 Alert Moderators
diystupid
from United Kingdom
PostPosted: Sat Aug 07, 2010 3:24 pm Reply with quote
Thanks for replies so far.
Ok, its 15mm pipework. No ptfe used.
Will try to explain this as best as I can. We have a ball joint on both the feed and return. We have disconnected the return pipe just before the ball joint just to make sure water was actually going through. Eventually the water coming out gets hot and the radiator heats up. But the pressure of water coming from the other side of the ball joint on the return is as high as the pressure of water going into the feed.
Once we connect the return pipe back into the ball joint, the rad starts cooling down. So its like we dont have a flow of water in and water out and two pressures of water are kicking against each other.
Any ideas.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1467 times
PostPosted: Sat Aug 07, 2010 3:37 pm Reply with quote
have you tried closing all the other rads yet?
it isn't a tower rad or towel rail, is it?
Back to top
 Alert Moderators
diystupid
from United Kingdom
PostPosted: Sat Aug 07, 2010 3:53 pm Reply with quote
no its not a towel rad/rail. its the rad in our living room. i am assuming that i can just turn off all the trv's to 0 and the one doesnt have one, simply turn it off? will get back to you.
Back to top
 Alert Moderators
doitall
from United Kingdom
Thanked: 1536 times
PostPosted: Sat Aug 07, 2010 3:55 pm Reply with quote
How many pipe do you have, do the two tails connect to the same pipe.
Back to top
 Alert Moderators
diystupid
from United Kingdom
PostPosted: Sat Aug 07, 2010 3:59 pm Reply with quote
all rads are off, i appreciate they will take a long while to cool right down but if this was going to work, how long would it be before the new rad would get hot?
Back to top
 Alert Moderators
diystupid
from United Kingdom
PostPosted: Sat Aug 07, 2010 4:00 pm Reply with quote
each radiator has one pipe in (feed) and one out. dont have a combi boiler and there is two tanks in the loft, one for water, one for central heating. also have an immersion with a self vent tap(?), where air can escape. dont have one of these on the boiler.
Back to top
 Alert Moderators
picasso
from United Kingdom
Thanked: 1278 times
PostPosted: Sat Aug 07, 2010 4:12 pm Reply with quote
what did you use to connect the rad valves where they go into the rad?
Back to top
 Alert Moderators
diystupid
from United Kingdom
PostPosted: Sat Aug 07, 2010 4:15 pm Reply with quote
simply screwed them on, they're compression joints.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 3
Jump to:
Brand new towel radiator leaking..... 13 1280 Mon Aug 10, 2009 11:21 am
Which radiator brand? 5 660 Sun Oct 17, 2010 7:03 pm
What brand of radiator? 4 380 Mon Mar 29, 2010 8:56 am
Which radiator brand to reccomend please 7 340 Wed Nov 03, 2010 6:05 pm
1 radiator not working - brand new house 3 4520 Thu Jan 05, 2006 12:10 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
