DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Lawnmower engines
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden
Author Message
dal5band
from United Kingdom
Thanked: 6 times
PostPosted: Mon Aug 09, 2010 4:32 pm Reply with quote
Anybody any info on who makes lawnmower engines ?
I was looking at Champion petrol lawnmower with the 150cc GGPSV35 engine. who actually makes the engines ? is it related to the Briggs & Stratton engine.
My old mower has a B&S engine which has lasted well but the deck is about to rust through. I'm not into the very expensive engined models.
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 159 times
PostPosted: Mon Aug 09, 2010 8:17 pm Reply with quote
All the info I can find on it says that it's a Mountfield engine.
http://tinyurl.com/37z5lgk
Back to top
 Alert Moderators
dal5band
from United Kingdom
Thanked: 6 times
PostPosted: Mon Aug 09, 2010 8:44 pm Reply with quote
Followed your lead to the Mountfield site and had a look at the manual for SV150 engine - It's made by SUMEC , Nanjing, China.
Back to top
 Alert Moderators
goodmow
from United Kingdom
Thanked: 2 times
PostPosted: Tue Aug 10, 2010 9:42 am Reply with quote
I repair lawnmowers as my job and the chinese engines are very unreliable,cheap yes but you get what you pay for.
If you can spend a little more money get something with a Briggs & Stratton or Honda engine on,it will be worth the money.
Back to top
 Alert Moderators
dal5band
from United Kingdom
Thanked: 6 times
PostPosted: Tue Aug 10, 2010 3:00 pm Reply with quote
I understand the SV stands for side valve - less complicated but ineffecient. Are the others side valve ie. is that the norm for lawn mowers ?
Back to top
 Alert Moderators
Stivino
from United Kingdom
Thanked: 159 times
PostPosted: Tue Aug 10, 2010 3:38 pm Reply with quote
I've been playing with my mowers today funnily enough. I have a Mountfield with the SV35 engine. It's not been running for a long time because the wheels are broken. I put some fuel in, checked the plug etc and it went second pull. I had a Briggs and Stratton in bits today as well and noticed that it's side valve too.
HTH , Stivino.
Back to top
 Alert Moderators
Ianthedecorator
from United Kingdom
Thanked: 1 time
PostPosted: Fri Aug 13, 2010 7:30 pm Reply with quote
I use lawn mowers every day during the summer ,even today and its bad weather ! The best engine without a doubt is the honda ,there superb ! we use a honda 16 inch 4 wheel self propelled mower for smallish grass areas ,i wont say lawns cos most customers dont have a proper lawn as such ,for bigger areas of overgrown grass we use a ibea 5hp 4 wheeler self propelled mower ,its a beast ! can cut dry grass 2foot long ,and belive me it makes us money,for any well cared lawn we use a hayter 17 ich roller mower but generally its too good a mower for most gardens ,you should avoid chinese engines as getting any parts is no go area ,also the best 2 stroke engines are GERMAN made by andreas stihl ,we use nothing else ,hope this helps .
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2602 times
PostPosted: Fri Aug 13, 2010 9:38 pm Reply with quote
Side valve engines are becoming somewhat passe due to their fuel inefficiency, although they are still fairly common.
Most manufacturers are using OHC or OHV engines and both appreciate regular oil changes.
Honda are using genuine 4 stroke engines in their brush cutters, and they contain a massive 80cc of oil...the theory is that there is so much oil splash around (no pump, needle roller big end) that there will be no oil starvation.
If you have a Briggs lookalike engine, of Chinese manufacture, regularly change the oil and kiss goodbye to any chance of obtaining internal spares!
Users need to realise that wet sump engines rely on splash lube so if your grass is on a steep incline then a 2 stroke machine may be needed, similar to the Victa, maybe.
For interest, check out the Stihl 4 Mix motor - a four stroke cycle engine using two stroke lubrication principles, twice over! Definitely the future.
This is definitely the kit to consider for daily professional use.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden All times are GMT
Page 1 of 1
Jump to:
Lawnmower engines 7 860 Sun Jun 12, 2005 11:27 am
Honda lawnmower 8 160 Sat Jul 07, 2012 2:13 pm
Car Engine oil in new Lawnmower 3 180 Wed Jul 11, 2012 11:51 pm
Lawnmower Went Over Stone - Now Noisy & Cuts Too Short 2 100 Mon May 27, 2013 4:50 pm
Lawnmower won't go in gear 4 120 Tue Jun 05, 2012 6:51 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
