Cutting Dado trunking lid
17 Apr 2009
Cambridgeshire
What's the best tool for cutting this stuff?
I've had the best success with the main parts by slowly feeding through a table saw, but is there a faster way to chop of pieces of lid?
Maybe some kind of guillotine?
I use a jig saw.
For MT trunking a pair of tin snips is perfect. With Dado trunking it's thicker and snips would deform / not cut correctly between the thin and thick bits of lid.
A fine finish TCT bladed chop saw and table for the trunking and the lid.
If i've got a lot of this stuff to cut I usually use a chop saw with a blade thats suitable for plastic cutting.
Gets it straight as a dye everytime, quick and simple.
Im also lazy btw :LOL:
a manual mitre saw, my chopsaw is a bit beastly for trunking lid though but if i had alot to do i would prob get a small £30 chop saw for the task, after all it isnt doing any strenuous work. :)
Yep, you can't beat it.
It has to be the quickest and cleanest way to do it.
just a hacksaw...
Perhaps for a couple cuts - not if your doing a room or rooms!
for a year and a half, myself, my mate and the 2 older sparkies we were working for were re-furbishing Worcester Royal Infirmary, most of which entailed changing old wards and the canteen into office space and consulting rooms, all of which had 3 compartment dado trunking in it..
the cuts don't need to be neat or even perfectly straight if you use the right trunking, the stuff we were using ( MK Prestige stuff IIRC ) had joint pieces with covers and pre-made corners etc so every cut was hidden....
there must have been about 2 miles of the stuff
And you cut it all with a hacksaw? Good god!
I always use clip on covers and pref fab tees.
You still want your mitres to be neat. Thats called pride.
hacksaw leaves a rough edge that you need to quickly run a file oer (or your fingers) to remove the swarf. A chop saw leaves the cut as clean as a factory end.
If you seriously did over 2 miles of the stuff and did not use anything other than a hacksaw then I really do pitty you!
We use Marshall Tufflex EMT20 for the majority of installs.
the corners are pre-made with their own covers so they were always perfect.. we only ever had to make straight cuts and a cheap mitre box from the DIY sheds took care of that..
the "fur" you talk about is easily taken care of with a stanley knife or a scraper.
