DIYnot
Local | Network
   DIYnot > Forums
Local | Network
my vauxhall vivaro cutting out then not starting
Post new topic   Reply to topic    DIYnot.com Forum Index > General Cars
Author Message
darren2010
from United Kingdom
PostPosted: Thu Sep 02, 2010 5:04 pm Reply with quote
i have a 2003 vauxhall vivaro and can any body help me with my problem ....when your driving along it just cuts out and wont start again.but wen bump started it is fine for a while then same thing again..please help or give me advice thanks
Back to top
 Alert Moderators
marcdtr
from United Kingdom
PostPosted: Thu Sep 02, 2010 5:48 pm Reply with quote
sounds like fuel pressure? maybe pump or filter?
Back to top
 Alert Moderators
jetex
from United Kingdom
Thanked: 22 times
PostPosted: Thu Sep 02, 2010 5:49 pm Reply with quote
Sounds to me like the fuel pump in the tank if failing. Sometimes they overheat and pack in. Once they cool down, they're o/k again.
Back to top
 Alert Moderators
andy189
from United Kingdom
PostPosted: Thu Sep 02, 2010 7:31 pm Reply with quote
sounds like your MAF senser is playing up..
Back to top
 Alert Moderators
Mickymoody
from United Kingdom
Thanked: 55 times
PostPosted: Fri Sep 03, 2010 3:05 am Reply with quote
Maybe a coil pack is failing?
Back to top
 Alert Moderators
jetex
from United Kingdom
Thanked: 22 times
PostPosted: Fri Sep 03, 2010 10:04 pm Reply with quote
Is the vehicle petrol or diesel ? You can try disconnecting the MAP sensor, but this will introduce a fault code into the ECU.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General Cars All times are GMT
Page 1 of 1
Jump to:
Vauxhall Vivaro 1.9TD cutting out fault 55 181700 Mon Feb 12, 2007 8:19 pm
My 2001 Punto's power steeting keeps cutting out? 6 1240 Thu Feb 21, 2008 3:39 pm
Ford Key / Master Key Cutting 4 16820 Sat May 13, 2006 8:44 pm
Starting problems with Vauxhall Corsa 3 2740 Wed Jul 29, 2009 7:55 pm
Petrol smell when starting up? 3 660 Mon Mar 26, 2007 1:24 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
