DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fixing railway sleepers together?
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden
Author Message
Tappers
from United Kingdom
Thanked: 1 time
PostPosted: Tue Sep 07, 2010 9:51 am Reply with quote
Hi
I have levelled up part of my back garden using railway sleepers help by RSJ's that I had concreted in by a builder. He advised me to drop the sleepers in to the RSJ's and then fix the top layer of sleepers on with coach bolts. I am having real problems finding any, looked online been to all sorts of wood merchants etc any ideas? Somebody told me I should be looking for sleeper ties, not bolts? Can't find these either!
Cheers in advance!
Back to top
The following user says thank you to Tappers for this useful post:
1019Richarda (27 Oct 2010)
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1098 times
PostPosted: Tue Sep 07, 2010 1:34 pm Reply with quote
coach bolts are very widely available
http://lmgtfy.com/?q=coach+bolts
http://shop.ebay.co.uk/?_from=R40&_trksid=p3984.m570.l1313&_nkw=coach+bolts&_sacat=See-All-Categories
but in a large size will work out quite expensive.
Consider Galvanised or Stainless studding, which you can cut to the length you want and will be cheaper. Use large washers at each end or the nuts will sink in. You can bore a pocket for the nut and washer to go in, to avoid scratching or knocking yourself on protruding bolt heads or nuts.
Back to top
 Alert Moderators
Tappers
from United Kingdom
Thanked: 1 time
PostPosted: Tue Sep 07, 2010 8:18 pm Reply with quote
Thanks JohnD I'm going to go for the studding!
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Tue Sep 07, 2010 8:33 pm Reply with quote
what are the odds that someone will be trying to nick your sleepers?
you are sitting them in the groves so that means that you have to lift them to get them out, so it's not like they're going to fall over, which is the only reason other than theft that I can think of for tying them together, stability..
Back to top
 Alert Moderators
Tappers
from United Kingdom
Thanked: 1 time
PostPosted: Tue Sep 07, 2010 8:52 pm Reply with quote
The rsj's aren't high enough to just sit the top layer in apart from the posts either end so I need to fix the middle 5 sleepers and the inner ends of the other 2.
I was unfortunately out when they put the rsj's, otherwise I don't think I'd have done it like this! Had enough trouble sawing bits off the ones that didn't need fixing down, never mind drilling through them now! icon_rolleyes.gif
Back to top
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Tue Sep 07, 2010 8:59 pm Reply with quote
I'm not following.. what exactly are you doing with the RSJ's and the sleepers?
photo's or pictures would help..
I imagined a set up similar to what you get with concrete fence posts and 6 foot gravel boards, but with sleepers and RSJ's..?
Back to top
 Alert Moderators
Tappers
from United Kingdom
Thanked: 1 time
PostPosted: Tue Sep 07, 2010 9:17 pm Reply with quote
Our garden slopes away and I have made a retaining wall out of railway sleepers to get a level lawn at the top.
The wall is 7 sleepers wide, with 8 rsj's, the RSJ's are set in at different levels as the garden had a steeper slope in the middle. The left of the wall is 3sleepers high, with the end of one dug in to keep a level line and goes up to 5 high in the middle, and back down to 3high at the other end.
The RSJ's at either end are high enough to put the outside end of the sleeper in but for some reason the 6 RSJ's in the middle are not high enough for the top layer of sleepers to fit in.. the builder told me this is what you are supposed to do, I have my suspicions he didn't buy long enough rsj's!
So now am having to bolt the middle sleepers all down. Bearing in mind they are each 300mm high it has been proving rather tricky to find something long enough to get through one of them, nevermind 2... I'll do some pictures tomorrow if this still makes no sense!
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1098 times
PostPosted: Wed Sep 08, 2010 6:45 pm Reply with quote
I have never done it myself, but on some garden programme I saw them building a wall with sleepers, and after building, they bored a 1" hole down through them, and banged in steel rods. I should think reinforcement rods would do, treated against rust.
Back to top
The following user says thank you to JohnD for this useful post:
Tappers (8 Sep 2010)
 Alert Moderators
ColJack
from United Kingdom
Thanked: 408 times
PostPosted: Wed Sep 08, 2010 7:31 pm Reply with quote
http://www.aspltd.co.uk/timber-frame-wood-screws.php
10 x 450 long screws available here with a large head..
use a flat bit to bore a 1 or 2 inch deep hole to sink the head into and thn get some dowel the same size ( or whittle a piece of timber to suit ) and bang into the hole, saw off flush and stain the same as the sleepers..
Back to top
The following user says thank you to ColJack for this useful post:
 Alert Moderators
Spr0cket
from United Kingdom
Thanked: 7 times
PostPosted: Thu Sep 09, 2010 8:19 pm Reply with quote
Are you sure the sleepers are 300mm, even on edge, most sleepers new or reclaimed come up at 250mm
Either way, as ColJackl has suggested, drill down 50 or 100 mm depending upon that sleeper height and insert these:
http://www.wickes.co.uk/Timber-Drive-Screw/invt/190113
Hopefully easy to pick up in a local store.
Wouldn't worry about plugging / staining etc, thes escrews will not notice - you've got steel rsj's all over the place, just be sure to treat any bored wood to maintain the preservation.
Back to top
The following user says thank you to Spr0cket for this useful post:
Tappers (9 Sep 2010)
 Alert Moderators
Tappers
from United Kingdom
Thanked: 1 time
PostPosted: Thu Sep 09, 2010 9:02 pm Reply with quote
Yes they are 300mm, I went to get a couple more and am having trouble getting them as I've been told ours are English and most are European?!
Thanks for the link. I am growing ivy over the top/back of them and they are going to be flush with the lawn and have a hedge in front of them so I don't think it will matter if screws stick up as they're never going to show- didn't want the kids touching them because of the creosote worries.
Back to top
 Alert Moderators
1019Richarda
from United Kingdom
PostPosted: Wed Oct 27, 2010 8:07 am Reply with quote
Hi
How the project going ?
I also wish to use sleepers and need to cut them up!
If I use a TCT cross cut blade in a power saw cutting though on both side any idea what the best number of teeth are ?
Oh the sleepers are brand new oak @ 130mm deep and 200 mm wide
cheers
Back to top
 Alert Moderators
Petest67
from United Kingdom
Thanked: 12 times
PostPosted: Sun Nov 14, 2010 10:40 am Reply with quote
I used sleepers and fixed mine together with galvanised building straps and decking screws (on side thats filled in with earth). I also fixed heavy gauge galvanised wire around the straps and pegged them into the ground then covered the whole lot with the soil. Its been up 5 years and no movement at all.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > In the Garden All times are GMT
Page 1 of 1
Jump to:
railway sleepers 2 580 Sat Aug 08, 2009 8:50 pm
Railway Sleepers in Garden 10 2520 Tue Feb 17, 2009 11:55 pm
Connecting 3 stacked railway sleepers 5 520 Fri Jul 16, 2010 2:56 pm
Railway sleepers as Garden steps 5 3500 Tue Mar 08, 2011 8:19 pm
Railway Sleepers on top of brick wall 6 180 Thu Sep 13, 2012 9:30 pm
DIYnot
