I'm installing a new kitchen in the near future and have just had a electrician round to look at the wiring I need doing. Currently, there are 2 double sockets on the ring main and an unused 32A cooker radial, which is not connected at the CU (wasn't used so previous electrician used its MCB to connect shower). I want to reconnect the cooker circuit to power electric oven, and increase the number of sockets to 5 plus connections for gas ignition and extractor. I proposed 2 different plans to the electrician to get a quote: (should say here, the consumer unit is about 10 years old, 80A main, all RCD, only 4 ways, 1 spare)
1. Use the spare way to re-connect cooker outlet to 16A MCB (cooker can be plugged to 13A), and also use this to power the gas ignition and extractor fan through a connection. Preferably hard wire everything so don't have visible cables. Add sockets to existing ring main.
2. Remove existing sockets from existing ring main, put in a new ring for the kitchen only and hard wire oven, hob and extractor.
He's said he can't do either because the CU isn't up to current standards and I would need a new one installing, in which case I may as well have a dedicated cooker circuit and new ringmain for kitchen only, as I'd have more free ways. Now, I've no problem with having this done, as long as he isn't taking me for a ride and doing unnecessary work. Secondly, if I had that done, I would have 2x 32A rings, 32A shower, 5A lights and presumably a 16A cooker, all on an 80A main fuse - is this too much? I've got another leccy man coming round this evening, and would like to know what I should expect to have done in your opinions?
