Vaillant Ecotec plus help needed
26 Sep 2010
London
I've just put my central heating on for the first time this year, but the boiler did not fire up and the display on the boiler is clear. I switched the power off and on and I could hear the boiler spring to life, & the radiators warmed up. However, I don't fancy having to do this every time I need heat! Any Vaillant experts out there? Help Please!
You should have had a radiator symbol in the display. This came on after you turned the power off and on?
What timer and roomstat do you have?
The display is blank. If I turn either of the dials it lights up blue, but no display?
It's a Drayton Lifestyle Timer, which was fitted last year with the boiler and a Honeywell thermostat which I never use?
I think it came with a year's warranty which I think has just run out as they keep ringing me to extend it.
The ecotec plus comes with a two year warranty as standard,call them out .it sounds like a display board fault, had one go faulty due to a power cut possibly a surge when power came back on.Just a note these people who contact you regarding extended warrantys read the small print its probaly home serve who in my experience so far havn't got a clue.
Yes it will b homeserve contacting u the ecotec plus has 2 year wArranty as long as u have it serviced by gas safe reg engineer at end of first year
