DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Painting bare-copper central heating pipes
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Author Message
Darkstar
from United Kingdom
PostPosted: Thu Apr 14, 2005 9:30 am Reply with quote
Hi all,
Having recently moved into a flat with a new central heating system, I now have to paint the exposed piping in all the rooms which is in bare copper.
Is there a special undercoat for this and/or do I need to sandpaper the pipes first to get a good bond?
Thanks in advance
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 148 times
PostPosted: Thu Apr 14, 2005 10:51 am Reply with quote
give them all a wipe with warm soapy water to get rid of any flux residue, and then a couple of coats of a decent undercoat and normal gloss will do the trick.
Back to top
 Alert Moderators
Panjandrum
from United Kingdom
PostPosted: Thu Apr 14, 2005 11:20 am Reply with quote
If you want white, you can get white plastic sleeving that slips nicely over straight pipe runs - great for the feed to radiators - avoids the need to paint.
Back to top
 Alert Moderators
Darkstar
from United Kingdom
PostPosted: Fri Apr 15, 2005 7:31 am Reply with quote
Two excellent tips - thank you both for that - it's much appreciated icon_biggrin.gif
Back to top
 Alert Moderators
sandwell
from United Kingdom
PostPosted: Fri Apr 15, 2005 11:18 pm Reply with quote
When I have painted copper pipes, I have cleaned down with hot water with a detergent, then painted with 2 coats of gloss, no undercoat, or primer. That is the method I read in a book, and found it worked perfectly.
Back to top
 Alert Moderators
TexMex
from United Kingdom
Thanked: 2 times
PostPosted: Tue Apr 26, 2005 11:55 pm Reply with quote
I sprayed our copper pipes with some radiator paint from the local plumbers merchant. The finish looks like enamel. In a bathroom, it really adds a touch of class.
I believe it's usually quite expensive, but the stuff I got was a freeby as it was redundant stock (colour matched to an obsolete range that they no longer stock).
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Wed Apr 27, 2005 12:12 am Reply with quote
do the next plumber a favour and leave them alone
Back to top
 Alert Moderators
trying
from United Kingdom
PostPosted: Mon May 02, 2005 11:09 pm Reply with quote
or as sandwell says wipe over with wet cloth and use gloss only, Dulux recomend this method. Sorry kev icon_lol.gif
Back to top
 Alert Moderators
HIGHRISE
from United Kingdom
PostPosted: Thu May 19, 2005 5:54 pm Reply with quote
You shouldn`t undercoat copper pipes, it often turns yellow . Just gloss, several coats if needed.
Back to top
 Alert Moderators
Zampa
from United Kingdom
Thanked: 26 times
PostPosted: Fri May 20, 2005 6:26 pm Reply with quote
Give them a light rub with fine wire wool making sure any flux etc is removed from the surface then two coats of oil based gloss, no undercoat as it is less flexible than gloss.
Back to top
 Alert Moderators
sr72
from United Kingdom
Thanked: 2 times
PostPosted: Sun May 22, 2005 8:55 pm Reply with quote
howdy,
just one thing,dont paint over the valves though.makes it a bit easier if you need to swing them down for decorating. icon_smile.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
Painting copper central heating pipes 3 3300 Fri Jan 26, 2007 7:08 pm
Wallpapering a chimney breast, but fireplace isn't central. 7 160 Thu Jul 14, 2011 8:01 am
Painting onto heating pipes 5 1080 Wed Jul 02, 2008 1:17 pm
Painting copper pipes 2 1860 Mon Mar 06, 2006 5:19 pm
painting copper pipes 2 600 Tue Oct 27, 2009 7:51 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
