DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Open Fire
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
LeonR
from United Kingdom
PostPosted: Mon Oct 04, 2010 10:49 am Reply with quote
We just bought a house and have cleaned up the fireplace. Its a 1985 building, the fireplace backing looks very clean.
Can you use a woodburner/open fire? Do all chimneys just 'work' or is it designed for gas fires?
How much does it cost to get it checked roughly? Also, can you even get really small wood burners? Seems a shame to have it and not use it (no gas there).
Cheers,
Leon
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3564 times
PostPosted: Mon Oct 04, 2010 11:00 am Reply with quote
Without the design information its difficult to know what it was designed for.
Again without trying a wood fire its difficult to know what it can handle and some ventilation from the outside will probably be needed if burning wood ( that introduces draughts ).
My suggestion is that if you dont need a wood fire then its better just to put the bowl of fir cones in the fireplace.
If you are hell bent on having a wood fire then ask your neighbours what they have and ask if you can see theirs in action.
Tony
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Mon Oct 04, 2010 2:37 pm Reply with quote
if its a standard brick built flue it probably had an open fire in the first place
so subjuct to a flue flow test it should be ok
Back to top
 Alert Moderators
LeonR
from United Kingdom
PostPosted: Mon Oct 04, 2010 3:05 pm Reply with quote
Ok cheers guys!
I wasn't sure if the heat can cause any problems!
Thanks!
Back to top
 Alert Moderators
adlplumbing
from United Kingdom
Thanked: 312 times
PostPosted: Mon Oct 04, 2010 3:31 pm Reply with quote
hi theirs is qual for this think it heatas or some to that effect
plus check if your not smoke free zone or u might get fined
Back to top
 Alert Moderators
Hugh Jaleak
from United Kingdom
Thanked: 713 times
PostPosted: Mon Oct 04, 2010 4:55 pm Reply with quote
I'd get the chimney swept and checked before attempting to use it. These guys: http://www.hetas.co.uk/ have a list of approved sweeps, who can clean and check the flue/hearth.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 990 times
PostPosted: Mon Oct 04, 2010 6:28 pm Reply with quote
An open fire should be fine as long as itís a class 1 flue. I had one in a previous property built in 1986 but if you install a stove it could change things somewhat. Modern wood/multi-fuel stoves are far more heat efficient & donít send so much heat up the flue which can cause problems if the flue is too large for the stove output (usually a 150mm dia max) or isnít properly insulated to prevent the gasses condensing in the liner. You should also be aware that installing a stove is notifyable building work unless you use a HETAS installer + there are several Building Regs you should comply with. Be careful, carbon monoxide kills very quickly & if you have some other problem, the lack of any compliance certification could mean no insurance payment! icon_wink.gif
Back to top
 Alert Moderators
RoyMacDonald
from United Kingdom
Thanked: 3 times
PostPosted: Mon Oct 04, 2010 7:24 pm Reply with quote
You can get modern woodburners that are OK for smokless zones as they burn totally cleanly. You would need to look at the manufacturers recomendations for the flue. A specialist shop would be able to advise you on an inspection of your flue.
If you just want an open fire try it and see as long as the flue is reasonable clean. If it fills the room with smoke you may have a bird nesting in the flue.
You can take an air supply from under the floor if they are suspended, or from outside if they are solid. A large woodstove in a small sealed room can reduce the oxygen too much and the fire will burn low and you will get a headache.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Width of open gas fire, and the need for a "Combustion& 8 100 Wed Jan 11, 2012 10:08 am
Draughty chimney and open flame gas fire. 6 60 Tue Oct 30, 2012 7:47 am
Air vent required for open gas fire? 29 5020 Thu Jul 13, 2006 10:28 pm
open fire back boiler 6 11220 Wed Nov 01, 2006 9:37 pm
multifuel stove instead of open fire? 7 800 Tue Sep 15, 2009 11:56 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
