The difference between the two ratings of VA and Watts is that the Watts rating encompasses a power factor rating( P.F.), without going into the technical side of it too much when any electrical equipment contains windings it has whats called inductance this property doesn't give a valid power rating as it is dependant on the circuit it is incorporated into hence the VA rating ( apparent power) as opposed to a power rating in watts. Basically any change in inductance will affect the reactance of the circuit and therefore the impedance and this in turn affects the current.
As a general rule of thumb, circuits are normally designed for a P.F. close to 1 (close to but not achieving 1 as this can cause problems in itself but thats another story) or unity power factor so if you say that VA is equal to Watts you aren't far wrong but i'd myself would allow a slight downrating to allow for the P.F.
So as stated above call it 60w but allowing a little derating i'd not put more than 50-55w load on it.
