Hi All.
I'm new here and this is my first post.
I have a problem with a Morco/Fagor FEB20EUK gas combi boiler fitted to a mobile home.
The problem is it will not run the central heating, However if you open a hot tap it will fire up and run perfectly for a long as the tap is open. When you close the tap the C/H works fine and it stays going until it reaches the temperature of the C/H stat . However once it reaches temp and cuts out it will not start up again unless you again open the hot tap.
When you turn it on it goes through the cycle, sparks, ignites the flame correctly then cuts out again after about a second then goes through the same cycle over and over again.
Now the problem is it's not showing any fault codes at all and all 3 lights on the display do work.
Water pressure is at 1.5 bar but I have by- passed the pressure switch, changed the flow switch, high temp stat and PCB to no avail
Any ideas?
Any help much appreciated as It's realy starting to annoy me!
Cheers
Any ideas?
Cheers
