Is .75mm cable ok for low energy downlights?
Also, the loop in/out connector on the fire proof casing has 6 points (3 per side, labeled Live Earth & Neutral, naturally!) So presume each side is just an in and out for the continuous cable? But does the earth not need to ground somewhere on the casing or something... where does it go once reaches the end of the line?
