DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Remeha Broag Avanta 39C Fault Code E10
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Westy180
from United Kingdom
PostPosted: Tue Oct 19, 2010 7:54 pm Reply with quote
Hi all,
I was wondering if anyone can shed any light on a fault with the above mentioned boiler.
The boiler was fitted just under 3 years ago, after 4 months it developed a fault (E4 code) Technician came out and replaced Ignition Transformer, all ok for about 3-4 months then it developed a shuddering noise for 1-2 seconds when starting up, we had several visits by Broag technicians who kept saying the Air/Gas mixture was incorrect, they would then adjust it, noise would re-appear after a few weeks, mixture would be adjusted again and so on..........when I questioned why the mixture kept going out of its parameters no-one would give reason, then they changed Gas regulator valve..............boiler fine for a while until colder weather and then noise has re-appeared, but fed up with complaining about it.
But tonight a new fault has occured, fault code E10 is showing and this has also tripped the electricity, attempted to reset boiler but fault is still present.
Contacted Broag tonight but we need to ring back tomorow as they say the warrany has run out, which I realise..........but surely we shouldnt have had so many faults with this boiler???
Sorry to have a long winded rant, but has anyone had any issues with this fault code (E10)?
And am I being unreasonable for expecting someone to look at it with some sort of goodwill involved?
Glen
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 787 times
PostPosted: Tue Oct 19, 2010 8:38 pm Reply with quote
Could be low system pressure, caused by a leak that is tripping the electrics.
Do you mean the govenor on the gas meter was replaced?
Back to top
 Alert Moderators
Tibbot
from United Kingdom
Thanked: 336 times
PostPosted: Tue Oct 19, 2010 9:08 pm Reply with quote
dangermouse46 wrote:
DM- Everything that uses that main heat exchanger is cr*p. You all argue about the same bl*ody boiler.
Back to top
 Alert Moderators
Egga
from United Kingdom
Thanked: 49 times
PostPosted: Wed Oct 20, 2010 9:03 am Reply with quote
E 10 happens during the venting cycle at start up and is usually a pump issue. If its tripping the electrics it could be leak as stated earlier. It can also be caused by air in the system.
I have experienced the "shuddering" start up and this was down to the burner cone working loose. Remeha engineer sorted it under warranty and been fine ever since.
Good boiler in my opinion. Hope this helps.
Back to top
The following user says thank you to Egga for this useful post:
gas4you (20 Oct 2010)
 Alert Moderators
Westy180
from United Kingdom
PostPosted: Wed Oct 20, 2010 11:43 am Reply with quote
I have contacted Broag this morning and they dont seem interested, awaiting a reply about a goodwill gesture as I still dont believe this boiler should have developed 3 faults in just under 3 years?
Replying to Gas4you, it was a gas valve within boiler that was replaced, not in meter. I did have old one until about 1 month ago then I threw it away as they never took it back with them under warranty.
I dont believe there is air in sytem but, did notice that when resseting boiler the pump will not purge system and it sounds like its seized which would explain electrics tripping.
Do I wait for reply from Broag or get someone to look at it, or put a pump on it.........
All good fun........NOT!
Glen
Back to top
 Alert Moderators
Paul Barker
from United Kingdom
Thanked: 826 times
PostPosted: Wed Oct 20, 2010 1:04 pm Reply with quote
Back to top
 Alert Moderators
Paul Barker
from United Kingdom
Thanked: 826 times
PostPosted: Wed Oct 20, 2010 1:05 pm Reply with quote
then make sure flux in system didn't damage old pump by flushing with a good cleanser hot and then fresh inhibitor after cleanser properly flushed out.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
broag remeha avanta 3 3400 Fri Feb 29, 2008 6:50 pm
Broag Remeha Avanta or Worcester Bosch or Vokera ? 11 2660 Mon Mar 08, 2010 8:39 am
Broag avanta ECO 28c combi ? 12 1060 Sat Sep 18, 2010 8:16 pm
broag avanta 28c 4 1560 Sun Aug 26, 2007 5:13 pm
Cheapest place to buy a Broag Avanta Combi Boiler 3 300 Wed Dec 08, 2010 11:01 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
