DIYnot
Local | Network
   DIYnot > Forums
Local | Network
HIGH LIMIT / LOW LIMIT / OVERHEAT STATS
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
jackecole
from United Kingdom
Thanked: 17 times
PostPosted: Sat Oct 30, 2010 11:31 am Reply with quote
WHat's the difference between a high limit stat, a low lmit stat, overheat stat etc? I know some boilers use a combination of the above but what's the difference?
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Sat Oct 30, 2010 12:22 pm Reply with quote
all the same just trip/switch at different temps icon_razz.gif
Back to top
 Alert Moderators
jackecole
from United Kingdom
Thanked: 17 times
PostPosted: Sat Oct 30, 2010 12:25 pm Reply with quote
Thanks for the quick reply kev
I take it a low limit stat is just your normal user stat/thermistor then?
High limit being same as an overheat?
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Sat Oct 30, 2010 12:32 pm Reply with quote
low limit stat is usually found on solid fuel
it stops the pump running till the boiler is warm enough to stop condensation forming
frost stat is sometimes called a loww limit stat as well
yeah high limit / overheat same animal icon_wink.gif
Back to top
The following user says thank you to kevplumb for this useful post:
jackecole (30 Oct 2010)
 Alert Moderators
spraggo
from United Kingdom
Thanked: 149 times
PostPosted: Sun Oct 31, 2010 10:42 am Reply with quote
These high and low limit stats were used on the old Thorn Apollo etc. They were activated by a rocker switch on the control panel marked high and low. The purpose of these, where to enable the user to select low in the mild weather and high in the cold weather. These two button type stats were fitted to the flow inlet side of the primary heat exchanger and were marked with a coloured dot to indicate their temperature at which they opened, which ranged between 135F and 190F.
The overheat stat shuts the boilers down if the water temp goes to high if either of these two stats failed
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 321 times
PostPosted: Sun Oct 31, 2010 10:53 am Reply with quote
Wee bit mixed up there Spraggo a low limit stat is different from a lo stat that was on appollos.
In domestic situation a low limit stat is what you get on warm air units ,burner comes on and the unit has got to get to a certain temp before the fan kicks in so that its not blowing cold air to start with
Back to top
 Alert Moderators
spraggo
from United Kingdom
Thanked: 149 times
PostPosted: Sun Oct 31, 2010 11:22 am Reply with quote
Thankyou for your correction namsag and I apologize, I was refering to high and low stats, not high and low limit stats.
spraggo
Back to top
 Alert Moderators
spraggo
from United Kingdom
Thanked: 149 times
PostPosted: Sun Oct 31, 2010 12:06 pm Reply with quote
Thankyou for your correction namsag and I apologize, I was referring to high and low stats, not high and low limit stats.
Please refer to the "similar topics" at the bottom of this page, where they are referred to as limit stats, whats the difference?.
spraggo
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Thorn Apollo high/low limit stats colour code 4 560 Fri Dec 21, 2007 8:28 pm
Honeywell Low & Hi limit pipe stats 19 5380 Mon May 16, 2011 10:20 am
Problem with limit thermostat or overheat cutoff thermostat? 2 80 Fri Jun 15, 2012 9:44 pm
Will changing high limit thermostat help 01 fault (vokera) 2 640 Wed Jan 20, 2010 10:58 am
heatslave high limit 4 60 Sun Oct 09, 2011 10:41 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
