Near to pump impellor (spined wheel) there is a black rubber non return valve,pull this out and water will run back from chamber on side of machine into dishwasher.This very often clears any blockage,then replace valve.If this fails this dishwasher is not one i would reccomend as a diy fix.Best of luck
