DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Sink Tap Water Flow
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
ecafisac
from United Kingdom
PostPosted: Mon Apr 25, 2005 10:25 am Reply with quote
Hi,the hot water tap in my bathroom sink has poor flow where water dribbles out. The cold tap is fine. I was wondering if there is some way I can adjust the flow?
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 918 times
PostPosted: Mon Apr 25, 2005 10:30 am Reply with quote
system is ??????
Back to top
 Alert Moderators
ecafisac
from United Kingdom
PostPosted: Mon Apr 25, 2005 10:36 am Reply with quote
sorry, not sure what you mean.
What are the types of system?
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Mon Apr 25, 2005 10:37 am Reply with quote
open vented
mains pressure
combi
Back to top
 Alert Moderators
ecafisac
from United Kingdom
PostPosted: Mon Apr 25, 2005 10:38 am Reply with quote
mains pressure....
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Mon Apr 25, 2005 10:40 am Reply with quote
check there isn't an isolation valve on the pipework
Back to top
 Alert Moderators
ecafisac
from United Kingdom
PostPosted: Mon Apr 25, 2005 10:44 am Reply with quote
What would an Isolation Valve look like? If there is one, how would I adjust it? ( is it a screw?)
Back to top
 Alert Moderators
kevplumb
Thanked: 918 times
PostPosted: Mon Apr 25, 2005 10:48 am Reply with quote
this is closed you turn the screw 1/4 turn to open it
Back to top
 Alert Moderators
ecafisac
from United Kingdom
PostPosted: Mon Apr 25, 2005 10:55 am Reply with quote
The link below shows my setup ( image 6 )
http://www.diy.com/diy/jsp/bq/templates/contentlookup.jsp?content=/bq_advice/common/howtos/fitbath/main05.jsp
Would the isolation valve be on the flexible pipes under the sink?
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 216 times
PostPosted: Mon Apr 25, 2005 10:59 am Reply with quote
Did it work ok & has now slowed, or was it ALWAYS poor flow
If it was ok, have you done or had done any work to the system
Back to top
 Alert Moderators
ecafisac
from United Kingdom
PostPosted: Mon Apr 25, 2005 11:06 am Reply with quote
Well we moved in about two months ago and it has always been like this. All other hot taps ( in the bath, kitchen ) seem to be okay. As I mentioned even the cold tap is working.
Back to top
 Alert Moderators
Slugbabydotcom
from United Kingdom
Thanked: 83 times
PostPosted: Tue Apr 26, 2005 1:28 am Reply with quote
Can I take you back to this ? by kev
Quote:
open vented
mains pressure
combi
You have a hot water cylinder of some sort then but do you also have any other tanks in the loft or cupboard perhaps?
Just trying to determine if it is indeed mains pressure you have for your hot tap as unvented or heatstore systems arent that common
Back to top
 Alert Moderators
ecafisac
from United Kingdom
PostPosted: Tue Apr 26, 2005 9:42 am Reply with quote
There is a cyclinder in an airing cupboard in the bathroom....
Back to top
 Alert Moderators
Gasman1015
from United Kingdom
PostPosted: Tue Apr 26, 2005 5:54 pm Reply with quote
Tap valve requires stripping down and lubricating.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Poor water flow to hot water tap on bathroom sink 5 760 Sun Mar 01, 2009 7:14 pm
bath and sink tap poor hot water flow 2 hrs to fill bath 2 640 Fri Oct 03, 2008 7:59 am
New kitchen sink /tap/ hot water flow reduced, cold water 4 1340 Tue Mar 28, 2006 10:45 pm
NEW KITCHEN SINK & TAPS = REDUCED HOT WATER FLOW 43 8120 Thu Dec 14, 2006 11:40 am
Kitchen sink - water doesnt flow! 14 980 Sat Jan 02, 2010 6:39 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
