DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Bosch 2021/2821 wash machine error code 3
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
doubledee
from United Kingdom
PostPosted: Thu Nov 18, 2010 9:09 pm Reply with quote
I have a 5 year old WFE 2021 that the lamps have started flashine with code 3, i have taken out the front panel and cleaned the filter thing which was solid with a grey scale, but it is still stoping mid cycle and showing 03
Is there any more areas that need cleaning or checking, the impeller does turn. Strangley if you put it on spin cycle it clears all the water out. The other thing i noticed is the pump seems to run for ages whne you can see no water in the drum, all help appreciated. Ta
Back to top
 Alert Moderators
zipper
from United Kingdom
Thanked: 505 times
PostPosted: Thu Nov 18, 2010 9:58 pm Reply with quote
F3 indicates a drain issue. Providing there are no blockages in the pump, sump hose, or waste hose then changing out the drain pump should cure your problem.
Back to top
 Alert Moderators
doubledee
from United Kingdom
PostPosted: Sat Nov 20, 2010 8:19 pm Reply with quote
Sussed it !,
If you take the back panel there is a small plastic square box clipped to the drum, this senses pressure depending on how full the drum is with water, in my case the pump was running and timing out cos it thought the drum was still full of water, take the box off and the hole behind it was clogged solid, cleaned it out and the box , also cleaned out the large plastic bottle clipped inside the rear rear panel connect to the outlet pipe , this has a doublle internal layer so although it lets waste water out it seem seems to rstrict it, Now the machine fills up with so much less water, and runs smoother, fills quicker and empties quicker, and cleaner. A RESULT!, with no parts needed. Don't always assume it is a pump if the mainhose and filter is clear, get the back panel off and clean these two,its worth it !
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Bosch Washing Machine WFE2021/2821 Problem 8 1600 Thu Jun 10, 2010 5:36 am
Bosch WFE 2021 Problem 4 280 Thu Dec 09, 2010 9:28 am
smeg dishwasher empties after wash then alarm bleeps code 8 2 560 Tue Jun 02, 2009 12:18 pm
Bosch WFK2801 Washing Machine Error Code 06 no action 5 1560 Tue Nov 03, 2009 9:30 pm
What dose error code (E90) mean on a zanussi washing machine 2 19220 Tue Aug 26, 2008 12:12 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
