Planning permission - Removing a fireplace??
28 Apr 2005
I am wall mounting a 42" plasma TV on the firebreast. I have taken down the fire surround and had a gas fitter remove the wall mounted gas fire and capped the gas pipe today.
I want to have the fireplace taken out and put up glass shelves in its place to put my sky receiver, DVD recorder etc... The opening requires widening slightly. I haven't checked the size of the lintel currently in place and am aware this may require replacing with a longer one.
Do I require planning permission of any kind before this is done?
I may add, I do not intend doing the work myself as I would probably bring half the house down :oops:
Thanks for your advice in advance!
Are you taking out the entire stack? (above roof) if not then you probably just need building regs
Yup I believe Building regs are all you need for this...
About 10 years ago I moved our fireplace to the left slightly, so it just meant some basic re-routing of the chimney stack....at the time I didn't bother with building regs though.
If you want to be extra safe just contact your local building control office or send them a brief outline of what you plan.
