Rotate soil stack - lubricant?
12 Dec 2004
Hey!
I need to rotate the toilet 'branch' on a soilstack by 90 degrees.
I've done it before ok, by popping a length of pipe in and using leverage. But this one seems not to want to move. I'm guessing it's 40 years old now, maybe.
Anyways... is there a lubricant I could pour around the connections to try and break the seal between the rubber & plastic? Maybe washing-up liquid?
Ta!
well u got to make sure its not solvent welded for a start and fairy liquid rots the seals you can use silicone grease but its doubtfull it will penetrate into the jointwithout any movement
Hmmm!
1 of those rubbers which doesn't like washing-up liquid, eh?
Silicone grease, though useful stuff, is nowhere near fluid enough to penetrate....
I may just have some liquid silicone still - time to turn the garage upside down again I think!
Thanks for the input!
WD40 might do the trick and it's not damaging to the rubber. ;)
Oh? I assumes str8 away that it would wreck it!
Thanks for that!
*Gets can out and has a look......*
