DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Vaillant ecoTec Plus 615 problems
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Michael85
from United Kingdom
PostPosted: Tue Dec 07, 2010 3:34 am Reply with quote
hey guys i was reading through some of your posts and you seem to know alot about these boilers ive got a ecotec plus 615 all was working fine until today we had a power cut which lasted for about an hour when all was back on the boiler fired up fine i had to reset the timers and so on the boiler ran for about an hour then switched off i went up to press the override and nothing happened i went down to the boiler and the H/W was fine but no C/H i pressed the i button and its given me the s.30 code and now the heating wont come on if anyone can help me it would be much appreciated
many thanks
Mike
Back to top
 Alert Moderators
linkyplumb
from United Kingdom
Thanked: 168 times
PostPosted: Tue Dec 07, 2010 5:47 am Reply with quote
Double check your central heating control.
S30 means that no demand from external controls.
What programmer is it?
Graham
Back to top
 Alert Moderators
Michael85
from United Kingdom
PostPosted: Tue Dec 07, 2010 11:33 am Reply with quote
Graham
thank you Graham for your reply ive checked the the controller and all seems fine there i came down this morning and the boiler has sprung in to life again its now showing the little rad sign on the display but this flashes every now and again but im still not getting any hot water to the rads
sorry to sound stupid here but i dont no what you mean by what programmer is it?
thanks again
Mike
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3612 times
PostPosted: Tue Dec 07, 2010 4:31 pm Reply with quote
The 615 is a heat only boiler.
These are ( normally ) installed with a programmer where you can set the times for heating and hot water.
That may need the power disconnecting for a minute as they sometimes get upset when they suddenly lose power.
I went to a boiler repair on monday and whenb I arrived there was a power cut but it came back on before I had finished.
Tony
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Vaillant Ecotec 837 Plus Flow problems 11 400 Mon Jul 19, 2010 5:09 pm
Vaillant Ecotec Plus 831 pressure problems 5 480 Fri Oct 21, 2011 6:55 pm
Hot water/heating problems with Vaillant EcoTec Plus 824 3 1340 Wed Apr 16, 2008 2:15 pm
Problems with Vaillant Ecotec Pro 24 boiler and Danfoss ther 49 1980 Wed Oct 16, 2013 10:40 pm
Vaillant 837 Ecotec. Gas Inlet Pressure Problems 18 5060 Wed Mar 11, 2009 1:18 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
