DIYnot
Local | Network
   DIYnot > Forums
Local | Network
ELECTROLUX BUILT IN DISHWASHER
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
Author Message
nskeates
from United Kingdom
PostPosted: Fri Dec 10, 2010 6:43 am Reply with quote
Hello,
I have got the electrolux dishwasher that has started to play up. Its about 5 years old and used daily.
When i put it on a cycle to wash the water will drain ok but i get no water spraying from the rotating arms at all.
I have checked the feed and thats ok, i took the left hand side off the machine and you can see the water go in and into a sort of flat maze thing that sits on the side of the machine and is very thin, it passes thro that ok and then goes down thro the salt chamber which again seems ok but it then passes thro what looks like a container of thick brown gunge !! when passing thro this it seems to be restricted. should this gunge stuff be in there ? the dial clicks thro its cycles ok but just don't get any water from the rotating arms.
anybody got any clues ?
thanks
neil
Back to top
 Alert Moderators
PrenticeBoyofDerry
from United Kingdom
Thanked: 1833 times
PostPosted: Fri Dec 10, 2010 7:51 am Reply with quote
The spray arms may well be blocked up and stopping them from functioning correctly. This will also prevent them from spinning around during the cycles.
So remove them and give them a clean under the tap, it's usually a case of undoing a plastic nut for removal.
Not sure what the gunged filled container is, but it sounds like it needs a clean too.
What model is it?
Do you have the manual?
If not try this link
http://www.usersmanualguide.com/electrolux/dishwasher
Back to top
 Alert Moderators
nskeates
from United Kingdom
PostPosted: Fri Dec 10, 2010 7:59 am Reply with quote
thanks for the reply.
model number is Product Number Code:911841111 ESL6114.
will try the arms but would have thought it strange for both arms to be blocked at the same time.
i think the red/brown stuff is all to do with the water softening system (i think)
thanks
neil
Back to top
 Alert Moderators
Leccy758
from United Kingdom
Thanked: 196 times
PostPosted: Fri Dec 10, 2010 8:11 am Reply with quote
If the brown 'stuff' is like small crystals in the matrix then yes they should be there.
The motor start capacitor on the circulation pump may have failed or the pump impeller could be blocked.
Back to top
 Alert Moderators
nskeates
from United Kingdom
PostPosted: Fri Dec 10, 2010 10:00 am Reply with quote
Thanks,
Where roughly can these parts be located.
thanks
neil
Back to top
 Alert Moderators
nskeates
from United Kingdom
PostPosted: Mon Dec 13, 2010 3:46 pm Reply with quote
thanks for the help, it turned out to be the motor start capacitor.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
does an electrolux built in need ventilation opening 11 1160 Thu Dec 27, 2007 7:15 pm
electrolux built in cook and hob blown 8 900 Sun Jun 20, 2004 7:37 pm
Electrolux Dishwasher ESI 602 X tripping 3 60 Fri Feb 17, 2012 9:00 pm
Electrolux ESL6115 Dishwasher not working 5 260 Thu Sep 29, 2011 9:26 pm
Electrolux ESL63010 Dishwasher not heating or drying 2 480 Sun Oct 23, 2011 12:43 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
