I have just moved into a new house that has a Gainsborough Ambassador thermostatic shower mixer installed. The issue is that when trying to use the shower the temperature will vary from very hot to very cold throughout the duration. This is less pronounced if the central heating is on at the sometime & is very bad when the heating is off.
I have taken the front off the unit & can see that it has the pink cartridge designed for combi boilers fitted so I would assume it should work properly. It does look quite old so is there a simple way to know that it is definitely knackered?
The boiler is a Puma 8e & normal hot water & central heating works fine.
Any advice would be great.
Thanks.
Thanks.
