Like someone else on this site I have a 100e that is leaking water from behind the domestic hot water micro switch. It seems to be leaking from the plunger pin, can this be removed, serviced/replaced by just undoing the 4 screws on the front of the plunger module?
Sorted!!
turn water & power off. Slowly remove the 4 screws, drain out about half a cup of water, remove cover. Diaphragm cover assembly £13.28, new rubber daiphragm £0.95, all done!
