Brick built Shed/Lean-to
1 Jan 2011
Staffordshire
Helllo and Happy New Year All,
Hope you can help?,
I am thinking of building a 8.5m x 2.4m Brick Shed which will have a front 3.5m section of Polcarbonate Roof and 5m of Steel Sheet roof, Its Roof will be 2.4m high sloping down to 2m high on one side, It will have 2.4m of the Polycarbonite section along side my Bungalow and enclosing the rear side/Kitchen Door.
1. Will i need Planning?
2. Will i need Building Regs?
3. Do i need 1/2 or single brick walls?
4. What size (width x depth) Footings do i need on Clay soil?
Any Help/advice will be gratefully accepted.......Thanks.
Maybe - google for permitted development
Maybe not, but again google for the dimensional and other criteria for this type of work in context of your property. If the kitchen door is an exit route for fire, then b/regs may be involved
Well, you need some sort of wall and a single skin is an option if you want the potential damp and cold interior
No-one can answer that. But a a minimum depth will be 600mm, and if you don't go deeper you may experience seasonal movement of the structure.
Thanks......
I will have to apply via Enquiry Form to see what this needs.
Regarding the Walls i feel 1/2 brick will be fine, If i include a Membrane that should stop the Damp.....This IS a Shed (posh one)
Footings..... I thought 400mm x 400mm should be OK
Any more info/help appreciated............THANKS.
Check the depth of your existing bungalow foundations and match that.. unless your bungalow is sinking..
