Hiya, this problem has only just occured and the system has been working fine up until now and no work or alterations has been done to the system.
Noticed last week that the shower (Mira Excel running from a Bosch condensing combi boiler) doesn't get hot enough for a comfortable shower and is tepid at best even with the Excel control knob set to override the max temperature stop. The only way to get a really warm shower is to set temp to max and turn the flow control down to almost minimum. The water from the bath and sink hot taps also starts off hot but soon becomes tepid.
Called British Gas to check the boiler and they say it is working correctly and they checked the temperature difference of running hot water downstairs and upstairs and there is an 18 degree difference! The kitchen tap is the first in line from the boiler.
The engineer said he had not seen that before and suggested that maybe there was cold water entering the hot water system thru the shower controls.
Is this possible. I need to be sure before forking out nearly £100 on a new cartridge for the shower ! Any suggestions please?
Many thanks
Many thanks
