Hello all,
I have just moved into a new property, which is fitted with a Baxi Bermuda 552 back boiler. It seems to be working without fault, keeping everything nice and warm.
There was no TV aerial in the property so I installed a shiny new one last weekend and the freeview coverage was perfect, until the boiler fired up.
Every time the boiler cycles on the freeview signal on all the TVs is scrambled until it turns off. From the reading I've done this seems to be a fairly common issue with Baxi boilers and most suggest it’s an issue with the thermostat/ suppression of it.
I opened up the thermostat cover and found that there is a suppressor fitted. My question is, is it possible that the suppressor has worn out or is it that the thermostat has worn? What should I replace, if anything?
I'm pretty desperate to solve it as I assume this will be affecting my neighbour’s signals too.
Thanks in advance.
Tom
Thanks in advance.
Tom
