Baxi 552 playing up can you suggest an answer please.
The heating side is working fine, Burner goes out after 2-3mins.
Disconnected thermostat on tank and connected the hot water valve direct to the signal wire from boiler to eliminate tank thermostat,
Removed thermo coupling from boiler to eliminate that.
There has been a new programmer fitted six months ago, so its unlikly to be that.
Pilot light is burning well.
But the burner persist on going out after 2-3mins!!!
Appreciate suggestions
Regards
Regards
