DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Using a resistor to reduce voltage
Goto page 1, 2  Next
Author Message
RF Lighting
from United Kingdom
Thanked: 1059 times
PostPosted: Thu Jan 13, 2011 10:08 pm Reply with quote
Evening.
I've just bought my self a CT meter off ebay.
The display is an LCD screen with backlight, so requires a power supply.
It requires ~12mA at 12V
The stated input range is between 8V and 12V AC or DC.
Would a resistor be suitable to reduce the voltage for this, and if so, what size might I need, or am I being crazy and ought to use a small transformer?
Thanks in advance
Back to top
 Alert Moderators
westie101
from United Kingdom
Thanked: 283 times
PostPosted: Thu Jan 13, 2011 10:15 pm Reply with quote
Resistor
V/I=R
Back to top
 Alert Moderators
DetlefSchmitz
from United Kingdom
Thanked: 90 times
PostPosted: Thu Jan 13, 2011 10:32 pm Reply with quote
If you mean drop the voltage from 230V then yes, you're being crazy. You would need a 3W resistor, which is highly inefficient, but worse, if the device took less current than expected, it would experience an over-voltage. A proper power supply is only 3 or so.
Maybe you meant something different though.
EDIT: PS. What's a CT meter?
Back to top
 Alert Moderators
wingcoax
from United Kingdom
Thanked: 157 times
PostPosted: Thu Jan 13, 2011 11:26 pm Reply with quote
Current transformer?
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 1921 times
PostPosted: Thu Jan 13, 2011 11:59 pm Reply with quote
Back to top
 Alert Moderators
MrTinker
from United Kingdom
Thanked: 26 times
PostPosted: Fri Jan 14, 2011 12:34 am Reply with quote
Would CT = cathode tube icon_question.gif icon_question.gif icon_question.gif
Am i getting this right you want to drop 230 down to 12 with a resistor?
Getting a trany for buttons would surely be better
Back to top
 Alert Moderators
riveralt
from United Kingdom
Thanked: 565 times
PostPosted: Fri Jan 14, 2011 1:32 am Reply with quote
Resistors in series is the way to go according to this site:
http://www.play-hookey.com/dc_theory/voltage_divider.html
Using 230v, 12v and 12mA got two resistors of 16k and 3.5k but had trouble calculating the voltage drop.
Good learning/ remembering experience though.
Back to top
 Alert Moderators
Beelzebub666
from United Kingdom
Thanked: 9 times
PostPosted: Fri Jan 14, 2011 2:32 am Reply with quote
The resistor size required would depend on the resistance of the appliance, and whatever rating it turns out to be I'm guessing you'd set fire to the carpet. Go have a look on ebay for a 12v power supply.
Back to top
 Alert Moderators
ccam108
from United Kingdom
Thanked: 12 times
PostPosted: Fri Jan 14, 2011 7:14 am Reply with quote
Yes you can, assuming the load will be fixed.
It's not obvious what you mean when you say the input is 8-12V AC or DC, as clearly 8V DC would be below the required input for the screen. Even 8V AC will only give you ~11.3V peak.
Also, if the input is as variable as you say, and AC only, I would use a transformer to up the voltage to around 15 and then rectify and regulate. A linear regulator would be fine for such a low current.
For an 8V DC supply you will need a step-up inverter to get 12V out.
Colin C
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 925 times
PostPosted: Fri Jan 14, 2011 7:59 am Reply with quote
AC/AC Multi-Voltage 500mA Power Supply only 13.99
A simple wound transformer with tapped secondary
http://www.maplin.co.uk/ac-ac-multi-voltage-500ma-power-supply-35927
Virtually any plug top power supply with the correct ouput voltage will do. I have even used transformers from fairy lights in emergency.
But avoid switch mode supplies as the 12 mA load will be too low for them and they may become unstable and the voltage become un-regulated and go too high.
Back to top
 Alert Moderators
echoes
from United Kingdom
Thanked: 108 times
PostPosted: Fri Jan 14, 2011 4:17 pm Reply with quote
Voltage divider circuits are only good when the voltage at the junction supplies a high-impedance input, which isn't the case here.
If the load is a constant 12mA, then a 3W, 18K resistor in series would work, but it would get very toasty, and if it failed s/c then the mains would fry your display.
A small, cheap transformer with a 9V to 12V secondary would be ideal (4 maplin)
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 1059 times
PostPosted: Fri Jan 14, 2011 6:13 pm Reply with quote
A CT meter is used to measure current. It is done by passing the wire you want to monitor through the centre of a current transformer (CT). This generates a voltage proportional to the current flow which is measured by a meter and converted to display the current flowing in the wire.
I'm not sure that the load will be entirely fixed. It might vary as the reading on the display varies.
I was partly trying to do this on the cheap, and partly wanting to limit the amount of space taken up by the components.
If someone could provide a link to a tiny little transformer that would be brilliant.
Back to top
 Alert Moderators
Beelzebub666
from United Kingdom
Thanked: 9 times
PostPosted: Fri Jan 14, 2011 6:17 pm Reply with quote
Back to top
The following user says thank you to Beelzebub666 for this useful post:
electronicsuk (14 Jan 2011)
 Alert Moderators
electronicsuk
from United Kingdom
Thanked: 275 times
PostPosted: Fri Jan 14, 2011 6:18 pm Reply with quote
Are you wanting just a transformer, or an AC-DC power supply? There are loads of small PCB mount transformers available, but you'll still need to add at least a rectifier and smoothing capacitor. Plenty of slightly larger (but still relatively small) chassis mount transformers are also available. Again, rectifier and smoothing required.
EDIT: I have also used these before as part of a job at work. Pretty compact and no other components required. They are PCB mount, but that's easily resolved with a bit of strip board and some terminals.
Back to top
 Alert Moderators
echoes
from United Kingdom
Thanked: 108 times
PostPosted: Fri Jan 14, 2011 6:19 pm Reply with quote
clicky
There is a 9V or 12V version.
EDIT: Is this just to provide power to a backlight (assuming since either AC or DC is OK)?
Back to top
 Alert Moderators
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Resistor Size 6 420 Thu Mar 02, 2006 11:04 am
Fusible resistor. 3 560 Wed Sep 26, 2007 6:09 am
Resistor Colour Codes - What Am I Doing Wrong ? 8 740 Wed Apr 12, 2006 9:50 am
Reduce number of switches in hall 5 220 Wed May 08, 2013 1:18 pm
Connectors blocks to reduce cable size for 12v lights 14 340 Tue May 20, 2014 3:18 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
