Hi there,
Our boiler is having a constant problem...
The timer is set and boiler seems to have no problem coming on/off at the right times, however, the fan doesn't run and the heating and hot water do no work. The light next to the egg timer like symbol flashes. If I switch the boiler off then on again immediately (the switch on the boiler, not the mains), it fires up no problem and the heating and hot water are fine. However, when it switches off with the timer and then comes to the next on time, we have the problem again.
So far we have left the boiler running full time as it has been cold anyway but have also been switching on and off manually.
Can anyone give me a clue what is wrong/how easy it would be to fix/what sort of cost would be involved?
Thanks very much!
Thanks very much!
