hello guys,
I have a gloworm boiler and have a little problem with the hot water.When the hot water is put on either on timer or manually(honeywell controller)it fires up and heats up the water.But on the controller display the little flame appears next to the tap symbol,but this stays on all the time even when its been on for an hour and obvoiusly the water is hot,this stays on and the pump is still running upstairs.It does not go off until the timer switches off and then the pump goes off after about 10 mins.The centralheating flame goes out ok and switches the pump off after about 10 mins even with the heating on constant,the flame just comes on when it needs to switch on the boiler.Im sure the water was also like this originaly but it no longer runs without the flame and pump running.I would be grateful of any help.
Thanks alot
Thanks alot
