DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Worcester Heatslave keeps locking out
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
Goulders
from United Kingdom
PostPosted: Sat Mar 12, 2011 6:25 pm Reply with quote
A friend of mine is trying to sort out a problem with her boiler. It is a Worcester Heatslave 15/19. She recently ran out of fuel and on refilling the oil tank, the boiler kept locking out after around 15 mins. I have had a look and oil is getting to the pump. I have vented the pump to ensure there was no air and all was fine. However, I also found that the CH pressure safety valve was operating and the gauge was at 3 bar. The water wasnt pouring out, but a steady/slow flow was present. I then found that the filling loop had been left open (for several months!!). I have switched the filling loop off and the pressure is now at around 1.25. It doesnt matter whether DHW or CH is individually calling for heat, the boiler still locks out after around 15 mins. Any ideas?
Back to top
 Alert Moderators
oilhead
from United Kingdom
Thanked: 175 times
PostPosted: Sat Mar 12, 2011 9:35 pm Reply with quote
Try the oil pump solenoid valve
Back to top
 Alert Moderators
Goulders
from United Kingdom
PostPosted: Sun Mar 13, 2011 7:32 am Reply with quote
Is there a way to test it?
Back to top
 Alert Moderators
oilhead
from United Kingdom
Thanked: 175 times
PostPosted: Sun Mar 13, 2011 10:16 am Reply with quote
Before starting, measure the resistance reading accross the coil. Should be around 2.7K. Run the boiler until it locks out and measure again. If no continuity, coil needs to be replaced. They fail when hot.
Back to top
The following user says thank you to oilhead for this useful post:
Goulders (14 Mar 2011)
 Alert Moderators
Goulders
from United Kingdom
PostPosted: Sun Mar 13, 2011 9:49 pm Reply with quote
Cheers for that. Will give it a go.
Back to top
 Alert Moderators
Goulders
from United Kingdom
PostPosted: Mon Mar 14, 2011 8:44 pm Reply with quote
Spot on. Solenoid has been changed. Works great. Thanx very much.
Back to top
 Alert Moderators
oilhead
from United Kingdom
Thanked: 175 times
PostPosted: Mon Mar 14, 2011 8:53 pm Reply with quote
Glad it's sorted. Being as you've saved a call out fee, how about a contribution to Red Nose Day?
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Worcester Bosch Danesmoor 20/25 - locking out 8 80 Wed Jan 11, 2012 10:37 pm
Worcester 20/25 oil combi running then locking out 2 20 Sun Oct 16, 2011 9:50 pm
Worcester Boiler keeps locking out 6 780 Thu Oct 04, 2007 9:18 am
Suprima Overheating and Locking Out - Not PCB 8 620 Sun Nov 18, 2007 9:47 am
biasi 28s keeps locking out 5 360 Wed Jan 02, 2008 7:43 pm
DIYnot
