DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Mould on loft timbers
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
Author Message
BenELL
from United Kingdom
PostPosted: Mon Mar 14, 2011 11:24 am Reply with quote
I have superficial mould growth on my loft timbers due to what I believe is lack of ventilation. I live in a mid terrace with large loft conversion and it seems there are no eaves vents coupled with insulation stuffed down between rafters by previous owner of home. Getting some vent tiles fitted on either side of the roof to provide ventilation. Once this is in place, what is the best way to treat the mould growth. Picture below if it helps.
[img]
[/img]
Back to top
 Alert Moderators
misterhelpful
from United Kingdom
Thanked: 360 times
PostPosted: Mon Mar 14, 2011 1:52 pm Reply with quote
I had the exact same situation a couple of years ago. I washed mould off with a sponge scourer and mild bleach solution then applied 2 coats of this:
http://www.cuprinol.co.uk/products/5_star_complete_wood_treatment_overview.jsp
It does tend to run down your arms a bit because you are basically working upside down, but I have not had any mould since.
Back to top
The following user says thank you to misterhelpful for this useful post:
BenELL (14 Mar 2011)
 Alert Moderators
Loki7430
from United Kingdom
Thanked: 1 time
PostPosted: Wed Mar 16, 2011 5:11 pm Reply with quote
I had exactly the same problem (water used to actually run down the timber). I used Polycell Mould Killer spray and with the ventilation tiles fitted its been fine since.
Back to top
The following user says thank you to Loki7430 for this useful post:
BenELL (17 Mar 2011)
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1434 times
PostPosted: Wed Mar 16, 2011 7:21 pm Reply with quote
the cuprinol products are very good once the timber is fully dry (so it soaks in). I usually use Cuprinol Green.
you should wear plastic gloves, eye protection, hat etc. If you turn the cuffs of the gloves upwards they will catch drips and stop them running up your arm. Wash very thoroughly including hair, and launder clothes afterwards.
You can get a coarse airless Cuprinol sprayer (like a garden sprayer but a different plastic so the solvents do not damage it) but in this case I would use a very effective mask and skin protection (these are poisonous products). Protect all electrical cables and water tanks, remove insulation to the opposite end of the loft; do not let the spray get into water tanks, lamps or switches.
see also advice about loft condensation at the top of the lofts forum.
Back to top
The following user says thank you to JohnD for this useful post:
 Alert Moderators
BenELL
from United Kingdom
PostPosted: Thu Mar 17, 2011 8:20 am Reply with quote
Cheers all,
Ill wait for the timber to be fully fry and then remove the mould and treat, thanks for the tips.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
what size timbers to stiffen ceiling for loft play room? 4 180 Wed Sep 12, 2012 4:16 pm
Loft Joist / Timbers 6 160 Sun Mar 18, 2012 9:05 pm
removing timbers 4 600 Sun Sep 23, 2007 9:30 pm
can i support from these large timbers?????? 3 400 Fri Apr 24, 2009 10:24 pm
Damp loft, mould etc. 4 100 Wed Mar 20, 2013 3:46 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
